Armoury crate Turbo mode + manual/max fan speed
Eufrazerijus
Hello everyone!
Is it possible to have the mode set to Turbo, but Fan Speed somehow set to Max? My laptop is too hot, but I am not confident enough to use Manual Mode.
Or maybe anyone knows how to set up Manual Mode that it would work the same as Turbo, but set Fan Speed at max?
Thanks,
HurricaneK
In my experience, you can just use Manual Mode. Don't worry, setting just the fan speed shouldn't be a problem at all, as long you dont change the GPU clock options.
Thanks for the answer! 🙂
