11-11-2024 02:39 PM
Hi all!
I have a problem when I select the scenario profiles.
It allows me to specify the volume and the RGB led's for the games but I can't control the fans. The custom configurations don't have this option.
Why is this function missing?
11-13-2024 03:36 AM
Had the same this morning after updating some sdk from in armoury crate.
After some searching and someone saying , install AI suite 3 and i gave that a try. after reboot , in armoury crate the fan control is back , strange though i cannot find any ai suit 3 program on my pc and its also not in control panel installed programs, neither can i find it in settings / apps / installed apps. What is AI suite 3 ? and
a month ago - last edited a month ago
For me here is the AI suite 3:
https://www.asus.com/motherboards-components/motherboards/prime/prime-z790-p-wifi/helpdesk_download?...
But this is already installed and it's still not working.
a month ago
Ok , i never had ai suit installed and installed it from Armory crate (from the utility tab in armory crate) version 3.03.33 . No idea why it then suddenly worked for me .
a month ago
And now you can control your fans with scenario profiles?
