Armoury crate hotkey problem
jucabala
I reset my ROG Ally Extreme, and the Armoury Crate hotkeys stopped working. I’ve downloaded all updates, restarted, made sure all services are set to automatic, reset it again, and nothing works. I appreciate any help.
joker39kenish
+, the same thing on Asus Tuf A15 (2023) laptops after updating to Armoury Crate v5.9.9.0. I also see problems with changing the GameVisual configuration. And if I enable Armoury Crate myself, I can't change the GPU modes (the ones on the right).test.png
Houstee
I had the same problem after the latest Armory Crate Control Interface update about a week ago.  Previous threads have said to hold down the power button until the computer shuts off forcing a hard shutdown.  I did not believe it would work but it did.
It sounds like there might be a conflict with the Armoury Crate software or drivers. Try reinstalling Armoury Crate, update all drivers via Device Manager, and check for BIOS updates. I was struggling to write an expository essay that was both informative and engaging, so I decided to use
https://academized.com/buy-expository-essay academized. Their service was outstanding. The essay was clear, concise, and presented the information logically and effectively. The writer followed my guidelines and used credible sources to support the arguments. It was delivered on time and exceeded my expectations. I’m thrilled with the results and will definitely use this service for future assignments.
