Armoury crate error 504 [serious problem] i will cry
lLegendaary
Hello Asus support i have issue showing this when i want to install armory crate on motherboard ROG MAXIMUS X FORMULA
90581
can someone help me because i need it to modify my asus theta 7.1 headset surround sound
Note : I have connection 1gig also firewall is off not block anything no vpn nothing fresh windows having this issue
also uninstall tool only open for 1 min and close automatically without giving error or something
also i checked if crate installed before there is no single armory crate file installed on my windows i just want to install armory crate what is this ?
thanks
12 REPLIES 12
lLegendaary wrote:
Solved from itself?
Somehow what the heck is going on it solved now ...
maybe the server i try to connect to was offline for 12 hours lol kekw
anyway appreciate
glad you got it sorted out.
KitchenThugJr
90581
thanks
Did You Find Any Solution To This As I'm Looking Into This Issue Since Past 3-4 Days And I'm Also About To Cry ;__;
Jesseinsf
90581
thanks
You need to close all RGB software before installing (Razer Synapse 3.0, Corsair iCue, Lian Li Lconnect, etc.). Basically just close everything in the taskbar overflow and system tray (Including any cloud storage such as OneDrive, Google Drive, DropBox, etc). After that, you can install Armoury Crate.
