05-01-2024 06:58 PM
Hello i have this empty device and component list issue so..
These are the steps I took;
-I downloaded the complete Armory Crate uninstall software and uninstalled it. (I said delete all my settings together)
-Restarted after successfully install the Armory Crate.
- I uninstalled them by checking them one by one in the control center.
Is there anything else I can do?
I don't want to reinstall the Windows again.
Solved! Go to Solution.
06-24-2024 02:02 AM
Hi, this seems to occur exclusively in the Turkish language. It should be resolved in Armoury Crate V5.9.4.0, which has already started rolling out (not everyone will receive it at the same time).
05-02-2024 02:24 PM
I'm having the same problem. I couldn't find a solution for days. I deleted and reinstalled the program many times, formatted it many times, but it doesn't solve it. What equipment do you use?
05-02-2024 02:34 PM
very annoying problem ( format atmak istemiyorum 😞 )
05-02-2024 02:35 PM
Oo bizdensin yeni farkettim 🙂 Hocam bu problem bendede var. Donanımların nedir. Hangi anakartı kullanıyorsun.
05-02-2024 02:37 PM
Msi anakart var z390 tomahawk olan i7 9700k 16gb ram 3600mhz ama format almak istemiyorum çok üzülürüm
05-02-2024 02:38 PM
Ben bu sorunun çözümünü günlerdir araştırıyorum çözemedim ve hatta bu sorunu yaşayan ilk sana rastladım. Bu da aklıma sorunun bölgesel olabileceğini getirdi. Şİmdi bölge ve dil ayarlarını değiştirip deneyeceğim.
05-02-2024 02:39 PM
eğer gelişme olursa yazar mısın? çünkü gerçekten yazılım çok kötü geliştirseler biraz daha süper olur.
05-20-2024 03:25 AM
still same updated.
05-20-2024 11:13 AM
Bende de hala aynı. Format atıp yeniden kurdum hala çözülmedi.
05-20-2024 01:02 PM
After you reinstalled Armory Crate, did you delete all residual files and folders in C:\Program Files (x86)\ASUS\, C:\ProgramData\ASUS\, and the AppData directories? If not, try cleaning those up, then reinstalling Armory Crate as an administrator. Also, make sure all your drivers are up to date and there are no conflicting programs. If the issue persists, it might be worth reaching out to ASUS support.
