ARMOURY CRATE does not find GPU TEMPERATURE source (problem has persisted for more than a year).
WagxCWB
ARMOURY CRATE does not find GPU TEMPERATURE source.
Randomly the PC locates the gpu temperature, others do not, when it locates it, it is saved in the profile and after restarting the PC the sensor disappears again.
- STRIX X670E-E BIOS(updated)
- VGA > AMD Adrelin 25.11.1(updated)
- RX7900XTX NITRO+
- ARMOURY CRATE (updated)
- W11 PRO 25H2(updated).
Topic without response:
https://rog-forum.asus.com/t5/amd-600-series/armoury-crate-does-not-find-gpu-temperature-source/m-p/...
9 REPLIES 9
WagxCWB
Any suggestions on how to solve it?
WagxCWB
The problem is recurring...
sometimes the PC starts with all sensors recognized...
MrAgapiGC
Level 17
correct happens on the last version of NVIDIA driver 591.67 i roll back and the sensor appear on the fanexpert4. i report that the same day of the nvidia driver deployment  23/12/2025
all data was send regarding that and 2 others.
all ac errors are gone with the last MEI drive clean clean for 24h test now i will check monday for the sensor reading on fanexpert4 later. is not rush for that for now.
There is no way to resolve it. fix it on user side. we wait. or if youa re on 25h2 with last drivers and bios roll back should get back the sensor.
Learn, Play Enjoy! We help and collaborate, NOT complain!
It's a real lottery to find this sensor; yesterday, for example, I restarted the PC 4 times so that on the fifth try the sensor would be detected.
msnskpl
I installed a brand new W11Pro and I have the same problem. After a few hours of figuring it out, installing Al Suite 3 helped (disabling memory integrity is required.......). The GPU option immediately appeared. Hey ASUS!!!! Do something about this.
Uninstalling Al Suite causes the GPU option in Armoury Crate to disappear again... so it must be installed on my pc...
I don't need Al Suite... there are too many different options, which I'm afraid to change hehe. I disabled the program's startup when the computer starts. And maybe I'll re-enable memory integrity even though the program is installed... 🙂 What do you think?
Geforece 591.59 driver
Z690 and i5-12600K platform
testing to see how the FAN EXPERT/ ARMOURY CRATE behaves.
starting to do the same let the fans speed up I am fine with it
Update is fine does what is on screen that put glad this is back ish!
Strangely, this alternative of disabling memory integrity in the BIOS seems to be working.
I turned on the PC a few times, and the GPU TEMPERATURE sensors were recognized (for now—I'm not going to celebrate yet because there's so much trouble with this Armoury Crate that it's better to wait).
Anyone else who can help test this incorrect behavior of Armoury Crate would be great.
As I said, there's no point in celebrating prematurely, I restarted the PC and the GPU Temperature Sensor was not detected by ARMOURY CRATE.
MrAgapiGC
Level 17
today appears from thin air from nowhere. i did check also today morning. I also made a clean install of windows. but that was yesterday morning. and i check also. i did not restart the pc since last night since i am working on something that i need.
So hurray? ish!
