09-14-2025 07:08 PM
After doing the latest update for armoury crate updating it to the latest version pretty much Playground was removed Assistant was removed so was Content had to reinstall everything and if that is normal then thats fine but the weird thing is the motherboard logo when turning on the computer wasnt there and just be on a longer black screen and then go straight to the windows and no I dont have fast startup enabled once I downloaded Playground and Assistant the Motherboard logo appeared again after restarting and shutting down. Assistant which was the second thing I downloaded had a event viewer 1000 crashing event something to do with the dll reloading or reloading could be normal could be not Im not sure now when downloading the content part on armoury crate same thing happened cause an event viewer error crashing event similar to the first one but a different .exe but aswell as the same .dll reloading in the event viewer now I just want my armoury crate and my pc to get back to normal because its weird when things change after updates and your not informed or there is nothing related to that on the forums after restarting or turning on my computer I would get notifications from armoury crate about my registered hardware I go to armoury crate my hardware is registered my GPU 4060 ASUS Nvidia and my Motherboard which is also registered with the serial numberr aswell for both Ive installed everything that can be installed on armoury crate and am still not getting the notifications from armoury crate about my hardware after boot which usually happens after installing all the other things from the feature library on armoury crate because they fixed the missing mobo logo on boot so i thought it would fix the missing notifications of my hardware but Im at a loss because there is nothing that I can update to fix this because everything is updated or installed and my notifications from windows are on armoury crate is the most recent one with banners and sounds I even checked what it does I dont get the notifications from armoury crate registering my hardware so im not sure unless I have to uninstall armoury crate and reinstall it but to be completely honest im not sure it doesnt make any sense event crashes in event viewer for two out of the three things in armoury crate that are add ons from feature library but still missing notifications from armoury crate about my hardware. any suggestions or anyone else having the same problem and found a fix would appreciate it otherwise imma just have to uninstall it and reinstall it
