Armoury Crate 6.3.6.0 - Lot's of Issue (Listed in body)
brylle_james27
Hello,
Everything is working fine until, I updated all the items under Update Center but I noticed my hardware and the software has been messing up
1. AC 6.3.6.0 is not showing my components details in dashboard (temp, frequency, etc)
2. ROG Ryujin III is showing SYSTIN instead of my default/usual temp monitored (CPU Package, Liquid Temp, CPU)
3.  Aura Sync is only showing Memory as Sync Devices instead of my MB, Addressable RGB strip(forgot the rest)Aura Sync.png
4. Apparently I found something as workaround/band aid solution. (But who want a band aid solution lol)
 a. Open Services in Task Manager and Restart the highlighted services
 b. Restart my pc.
c. Check if parts and software are working normally
Item Version
Armoury Crate UWP App 6.3.6.0
ROG Live Service 3.3.12.0
Aura Service (Lighting Service) 3.08.59
Armoury Crate service 6.3.6.0
Aura Wallpaper Service Not installed
Aura SDK 3.05.13
ArmouryDevice 4.2.4.7
ASUS AIOFan HAL 1.5.4.0
ASUS AURA Extension Card HAL 1.1.0.20
ASUS AURA Motherboard HAL 1.6.1.2
ASUS Ambient HAL 7.8.0.0
KingstonDram 1.1.44
AURA DRAM Component 1.1.29
ENE RGB HAL 1.1.60.0
ENE_EHD_M2_HAL 1.0.14.0
Patriot Viper DRAM RGB 1.0.9.8
Patriot Viper M2 SSD RGB 1.1.0.3
Universal Holtek RGB DRAM 1.0.0.7
WD_BLACK AN1500 1.0.14.0
AIOFanSDK 3.00.32
AIOFanSDKPlugin 2.00.02
MainSDK 2.01.47
MbLedSDK 3.00.57
Armoury Crate Plugin - Aio 2.1.1
Armoury Crate Plugin - Motherboard 1.3.0
ASUS Motherboard 4.08.04
ROG RYUJIN III 4.01.39
Xbox360 Controller Emulator 1.0.0.15
6 REPLIES 6
brylle_james27
Forgot to add
  1. I did uninstall, restart pc, reinstall. (Using official tools uninstaller and installer ofc).
  2. I did not touch registry just to fix anything
  3. I did not manually delete, rename, files under C:\Program Files\Asus\ and whatnot
  4. Tried clean %temp%, sfc scannow and etc
NDarcy
I'm having issues with this version too. I also don't see temps or frequency data. MB is gone from the devices list and its lighting effects have defaulted, and I have no control over it. I also don't have Fan Xpert or any way to control fan speed (this also used to show on dashboard). It looks like installing a component named something like ArmouryCrateMB_home 6.3.7.0 (I apologise if that's not the correct name, I'm not sure I remember it correctly) breaks it. If I uninstall AC and reinstall it, then everything is back to normal, but a reboot will break it again.
I have an old MB (Maximus Hero XI Wifi) but I have the latest BIOS. I also tried all the steps as the original poster (sfc scannow, etc).
For now I just reverted to using a rather old version of AC.
I also noticed this ArmouryCrateMB_home 6.3.7.0 and another 1 component that wants to be updated (forgot to capture). Then after that some shi are not working. Also, I reverted to older version but after a day or so. Once I open AC, it's updating and the cycle continuous lol wth
Edit: reinstalled old version just to capture the broken update 💔
Update:
ArmouryCrate.MB_HomeSetup is gone under Update Center not sure if it installed/updated itself but it messep up my rig again. 8e137916-566a-4c19-920b-449ad8345937.jpg1.png3.png2.png
Yes, it appears that ArmouryCrate.MB_HomeSetup is automatically installed, because I also always observe that behaviour. I uninstall AC, reboot, reinstall AC and everything is working, with those two updates pending (ArmouryCrate.MB_HomeSetup and VGADII). Then on the next reboot, everything is messed up again and ArmouryCrate.MB_HomeSetup is gone from the list of available updates).
NDarcy
I'm currently using version 5.9.14.0 without issues. That's the only old version I managed to grab from ASUS: https://rog.asus.com/us/content/armoury-crate/
It only asked me once after install if I wanted to upgrade it. The update is available if I want to do it, but it doesn't update automatically
I noticed that newer versions do have the tendency to self-update without prompting me, so I'm staying with this version for now.
