Armoury crate 6.1.13.0 Problem
Marly
Hello,
There is still a lot of work to be done on this version of Armoury Crate.
Why not display all fans and temperatures on the same grid like the old version, and not have to scroll with the mouse.
Another problem I encounter see screenshot when I do alt+tab during a video game the display of information from Armoury Crate is not complete then it becomes normal again it is very restrictive.
Why not let us choose to install or not the new version of Armoury Crate rather than imposing it on us which I find less efficient more memory-hungry and less fluid...
what a disappointment this update.
Screenshot 2025-03-10 at 11-00-18 Problème Armoury crate 6.1.13.0 - Page 2 - Republic of Gamers Forum - 1080430.png
26 REPLIES 26
Marly
I come back to you for a new problem since the last update of Armoury Crate on the game Path of Exil 2 the fans fan 1 set to standard go up to 1500 rpm which is not normal.
it blows too hard, then it stops and starts again at 500 rpm and sometimes they stop completely the GPU clock is saturated at times also this never happened to me before this update.
Please put back the old version because the ventilation is not correct it does what it wants.
See screenshot.
There is a serious problem of this update: the booting time is extended fourfold. After deinstalling and reinstalling version 6.1.13.0  the  error was corrected.
Marly
Thank you for your advice.
I've had my new computer for two months, and everything has been working fine except for the Armoury Crate update.
The rear case fan has started running very loudly compared to the other fans twice. This happened when launching Path of Exil 2, which I play almost every day.
All my BIOS settings are at default except for IA CEP, which I disabled to reduce CPU heat, which increases its voltage. So I don't think that's the cause.
Should I modify it and set Intel to Performance? And what are the differences? AI Tweaker "Performance Preferences," Intel Default Settings, or Asus Advanced OC?
See screenshot
For fan settings, I'm in automatic default mode, and sometimes I set it to silent in certain games where the fans are too noisy.
I think, You should ask Your ASUS support directly by E-Mail.
Marly
This is what I did, he asked me to contact the Armoury Crate support.
A priori, we cannot contact them directly
Marly
I tried installing this version: ArmouryCrateInstaller_3.2.11.2, but nothing worked; it automatically updates to version 6.
Today, just like yesterday, while playing a video game, after an hour, the chassis fan (Fan 1) went up to 1400 rpm and remained stuck without going back down. I had to push the fan acceleration time slider all the way to unlock it and allow it to go back down to a normal value without it being used.
Have You registered You hardware? Then You can get support from ASUS. Unfortunately I can`t resolve Your problem.
Marly
My motherboard was registered with Asus. I've been in contact with support by email, and they're telling me to contact Armoury Crate support. I don't know who to contact anymore; I'm well on my way. If only I could go back to the previous version, it's very disappointing.
