07-07-2025 01:26 AM
i was using the armory crate in asus tuf f15 FX507ZC4
Item Version
Armoury Crate UWP App 6.1.18.0
ROG Live Service 3.0.26.0
Aura Service (Lighting Service) 3.08.18
Armoury Crate service 6.1.18
Aura Wallpaper Service Not installed
Aura SDK 3.05.06
ArmouryDevice 4.2.2.8
ASUS Ambient HAL 5.7.0.0
MainSDK 2.01.37
AI Noise Cancelation Audio Software 4.0.6
i am updated the armory crate in update center after update the keyboard light controls are not working in my laptop
color modes are not changing and colors are not changing in the keyboard ,only brightness functions are working
when i rollback to previous version of armory crate it working kindly helpme to resolve the issue plz
07-07-2025 01:44 AM - edited 07-07-2025 01:44 AM
As I already wrote in the other thread, you should first install all the updates offered in ArmouryCrate, because they don't happen automatically.
So click "Update" and "All updates" to run the updates, as Armoury Crate 6.2.7.0 and newer are already available.
07-07-2025 01:59 AM
i have update to new version after the upadte only i got problem
now keyboard colors not working
07-07-2025 02:11 AM
You've installed the latest update now. You can manually check for further updates in Armoury Craft under "Settings" and "Update Center."
You should do that. Sometimes additional updates only arrive later.
You should also restart your laptop. Don't use the fast startup option, but reboot properly so that everything is recognized.
It seems your keyboard's RGB isn't being recognized correctly.
Please also provide a screenshot of what's being recognized under "Devices" and "AuraSync."
07-10-2025 12:53 AM
What is solution for this problem
07-10-2025 04:36 AM
I don't currently know what the solution is, as you haven't provided all the requested information.
Please read my post carefully again and provide the requested screenshots.
Furthermore, you should check whether "Fast Startup" is enabled and try disabling it in the power options.
With the information you've provided so far, it's very difficult to identify the cause of your problem.
Fab modes for the keyboard can be adjusted either in Armoury Crate under Aura Sync, which then applies to all RGB colors, or in Windows 11 under Settings/Personalization and then under Windows Dynamic Lighting. Your laptop keyboard should actually appear there if you're referring to the laptop keyboard and not an external one.
Since I don't use an Asus laptop myself, nor do I have an Asus keyboard that can display such RGB colors, I'm dependent on your information, just like every other user here trying to help.
07-11-2025 08:12 AM
i have a problem this issue. Anyone have fix yet?
07-11-2025 08:42 AM
probably wait for new update
