11-15-2021 08:18 AM - last edited 3 weeks ago by ROGBot
11-15-2021 01:21 PM
11-15-2021 01:08 PM
11-15-2021 01:31 PM
11-16-2021 04:09 AM
Nate152 wrote:
Just a suggestion...
Since this wasn't mentioned I'm on windows 11, if you have windows 10 activated it's a free upgrade. Could try this if you're not already on windows 11.
11-16-2021 05:20 AM
11-16-2021 12:37 PM
Nate152 wrote:
Windows 11 should install on z170,
Make sure PTT is enabled, on the Boot tab make sure Secure Boot is set to "other os".
Try installing windows 11 again, let's do a fresh install instead of the upgrade.
11-16-2021 12:48 PM
11-16-2021 02:57 PM
11-17-2021 07:49 AM
Nate152 wrote:
If you have PTT enabled windows 11 should install.
Do you have a 16GB flash drive ?
11-17-2021 08:19 AM
