11-15-2021 08:18 AM
11-15-2021 08:28 AM
11-15-2021 08:51 AM
11-15-2021 09:07 AM
Nate152 wrote:
Hey guys,
Please tell us a little more about the problem,
For instance, what all you're trying to control, what windows version and is it fully updated. Are you on the latest bios and all drivers updated. And does your motherboard meet the Armoury Crate requirements.
Things like this can help diagnose the problem. I'm on a z270 motherboard and know there are certain things I can't do.
https://www.asus.com/us/support/FAQ/1042459/
11-15-2021 09:16 AM
11-15-2021 09:37 AM
11-15-2021 11:32 AM
Nate152 wrote:
Try disconnecting your keyboard and reconnecting it, restart your pc too. I see your TUF Gaming K3 is on the supported product list so maybe it's something simple that will get it to update.
Just to confirm you're up to date with Armoury Crate.
Click the picture to make it bigger.
11-15-2021 11:42 AM
11-15-2021 12:13 PM
11-15-2021 12:45 PM
Nate152 wrote:tried that it just reverts to needing the update just checked in device manager and the driver has installed as a mouse instead of a keboard, so going to uninstall and remove all reg and services and try and install again, i dont suppose you just have a link to the driver inf file.
Thank you,
All you should need to do is click update and let it do its thing, I'm a bit puzzled myself.
What I will say though is...
Try it again, if you still get the "framework service not responding" we'll focus on this.
