Armory Crate Fan Xpert 4. Cpu package temp vs cpu temp ??
Niro1
Good morning, I have a problem with armory crate, Fan Xpert 4. My real temperature on after burner is "cpu package" But Fan Xpert 4 has the value "cpu temperature". This poses a problem for adjusting the fans according to the actual temperature during my applications. There is a 10 to 20° difference. I have to change my fan speed curve, in idle mode. How to choose "cpu package" for fans to follow this value. Thank you for your understanding. Cordially.
moyang_mm
I had the exactly same issue! Despite that I selected "CPU Package" as CPU Fan's source, the actual fan curve is still based on "CPU Temperature", which is consistently 10C lower than the "CPU Package" temperature. I have updated all ASUS software to the latest version (as of 6/15/2023). I have no idea how to fix this issue. It is really annoying!
Manjiiii
same problem here
