Armory crate fan control FanXpert4 alternative temperature sources do not load
Krewmen
I use Armory crate fan control FanXpert4 to read out alternative temperature sources.
Armory crate loads via Windows 11 autostart, and it is loaded as a window when I start my PC.
Even normal fan curves seem to work, but it does ignore the alternative temperature sources like my GPU.
If I click in Armory crate to FanXpert once, the alternative temperature sources are used, I can even exit the windows with x and it stays there.
Basically I want my case fans to ramp up when the GPU get hot.
So my question is - how can I make sure that the alternative temperature sources are used directly with the startup?
My specs are:
Define 7 Gray TG - ASUS TUF Gaming Z690-Plus D4 - i9-12900K - 3080 Ti FE - G.Skill 32GB DDR4-3200 - Samsung 980 PRO 2TB - Asus VG32VQ - Asus STRIX FLARE - Asus Chakram - be quiet! Silent Loop 2 280 - Straight Power 11 Platinum 1000W - Silent Wings 4x140
91016
20 REPLIES 20
GObonzo
are you inferring that you have access to Fan Xpert 4 directly through Armoury Crate?
or just that you are using Armoury Crate to download & install AI Suite 3 and then using it from the AI Suite 3 interface?
ASUS ROG Strix Z590-E Gaming | i7-11700K \ ASUS ROG Ryujin 360 | G.Skill TridentZ 3466 CL14 32GB | ASUS TUF RTX 3080 Ti | M2: 960GB \ SSDs: 5TB \ HDs: 16TB | Super Flower Leadex III 850w | Fractal Design Vector RS Blackout \ 5x be quiet! Silent Wings 3 140mm High-Speed PWM | Logitech G600 | Corsair K70 LUX RGB | Xbox One S Gamepad | Klipsch ProMedia 2.1 | Anker Soundcore Life Q20 | 34" Alienware AW3420DW \ 55" LG CX OLED | Windows 10 Pro x64
