About AI noise reduction,Asus //Utility audio driver
muyingzou
屏幕截图 2023-05-25 194740.png屏幕截图 2023-05-25 194755.png87cb43a98226cffcdf0b7306ae014a90f703eaf4.jpg
My AI noise reduction function failed after I installed and uninstalled voicemeeter, the audio device with AI-noise input or output was not listed by default in the audio settings as before, I thought there was a problem with its driver and wanted to reinstall it. But there seems to be a daemon service (Asus Utility) in the device manager that prevents me from doing so, so I uninstalled it. But now I have no way to install it back, and I can't find the relevant installer, resulting in the AI noise reduction feature being crippled as well. How do I go about doing this?
muyingzou
The third picture was found from a posting and is for demonstration purposes only.
Hasheen_Mohamed
Did you find any solution I have the same problem
