6 generations later and Armory Create still doesn't work.
CapticeTrice
Updated Armory Crate for my TUF B760 PLUS and since then the sound muffles out of no where and changing audio settings does not fix it or stops Create to also disable its own RBG profiles randomly.
How is it that Asus can't get the program for their own motherboards and devices to work right?
I kind of expected updates to break their main features from Microsoft, Apple, Samsung and Nvidia but Asus too?
This issue persisted since the Z390, the X570 and now the B760. All these updates and this audio bug still hasn't been fixed and I can't even roll back to a previous version before it started either.
Anyone recommend any recommended brands I should use next? Cause clearly Asus can't keep it together anymore and Gigabyte's gone full Toshiba.
KevinBaker
Frustrating experience! ASUS really needs stable updates for core features.
carrymarry
You're not alone Armory Crate has been buggy for a lot of users across different chipsets (Read More). If you're considering switching, MSI and ASRock are often praised for more stable software and BIOS updates. Might be worth looking into them for your next build.
