What Could Be the Bloody Problem. Deeply Needing HELP~~~~~~~~
yu0307
So there is the problem for the last half year......
My screen will bounce and flickers whenever i play some HD videos, Or playing games, Happens all the time during COD:Black OP2. Some times even gives me PC freeze or blue screen. back then,I was cross firing two asus 7970 DC2s I have some render problems like objects will have lines drawn over it. then i switch to ares2, at first it gives me errors like "AMD driver has stopped responding but has recovered.", That error went away as soon as i switched to the new RAM. now i'm having this flickering issue. I have tried any possible ways to identify the problem. But this thing is by now giving me thoughts to suicide.
My setups are as follows.
CPU:AMD FX8150 (Brand new purchased, 1 year old Good functioning) O.C at 4.4Ghz Multiplier 22, CPU ratio 200
Motherboard: Asus Crossair V Formular W/ Thunderbolt (Brand new purchased, 6 month old)
RAM: CORSAIR Vengeance 32GB (4 x 8GB) DDR3 DDR3 2133 (Brand New 2 days old) Running at 10-11-11-31 54 1.51V
Power Supply: Rosewill LIGHTNING 800W 80 PLUS GOLD (Purchased Brand New 1 year old)
Monitor: 27" Asus
HD: 1TB, Western Digital (Purchased Brand New 6 month old)
Operating System: Win 8 pro 64bit
I don't think other hardwares will matter in this case.
I have tried the following with no lucks:
-bought a new motherboard of the same type Formula V, And replaced 6 month ago. No luck
-brought a new set of Ram replaced the previous DDR3 2000 Kingston T1 3X2Gb last week. No luck
-Tried using a 1000W power supply, But not a 80 Gold Certified. Same problem, No luck
-Tried using a new HD of 1Tb, Reinstall the OS, Reinstalled Drivers..... NO luck
-Tried using new Beta drivers, or clean install OS then install stock Drivers....... NO luck
-Tried Running everything in AUTO in BIOS......NO luck
-Before Ares 2, I tried cross fire two of asus 7970 DC2s
-Single Asus 7970 DC2s..........No luck
What I have NOT tried:
-Install Win 7.
-Using a 80 gold certified 1000W
-Using a qualified vender RAM
-Crossair Formula V-Z motherboard
-CPU AMD FX8350 (Arriving tomorrow, See if it works)
-Another Graphic card.
Would Anyone please please please help me out. I don't think i have enough money to buy new parts to test them anymore.
Some body, Anybody, Please help me out here. ....
28 REPLIES 28
xeromist
Can you describe the flickering issue? Is it all the time or only when a 3D(DirectX) application is running? Have you tried another monitor or a different connector (HDMI vs DVI)?
Moderation note: Removed your duplicate threads since we ask that you maintain only one thread per issue. Thanks! 🙂
Hi, Thank you for the response.
I have tried different monitors. as well as different cable and different connectors.
This issue happens even in youtube.com. I don't think 3D is running by then. But so far the only game i have not seen issue is the Giuld war 2.
Please help~~~~
Please help~~~~
the flickering is like, the whole screen as an image will go off an inch for a split of second then back to normal . This thing happens randomly but often when playing game or watching HD videos.
HalloweenWeed
Level 12
Are you certain you don't just have known issues in CoD:BO2 when using Xfire? I had troubles W/AMD in Syrim W/Xfire and had to disable Xfire in Skyrim. AMD fail.
i7-3930K; Asus RIVE; G.SKILL Ripjaws Z 4x4GB DDR3 1866; MSI 7870 2GD5/OC; Crucial M4 SSD 256GB;
Corsair 1000HX; Corsair H100, 4x Excalibur 120mm PWM CPU Fan p-p, AS5; SB X-Fi Titanium Fata1ity Pro;
Dell U2412m IPS 1920x1200; Cooler Master HAF 932 case; Tripp-Lite OMNIVS1500 UPS fully Line-interactive.
(EVGA site: ) And I have a second (wife's) computer, Eve.
Overclocking is useless to me if it is not rock stable.
Myk_SilentShado
Level 15
Just out of curiousity, what DirectX do you have running? and were you forced to install any of the older DirectX packs? like the 2009/2010 editions?
Hi, I dont think i was forced to install other version, I am not really sure but from dxdiag. it shows D11 And i will post the entire report as follows:
System Information
Time of this report: 3/11/2013, 18:38:11
Machine name: WIN-8
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.130108-1504)
Language: English (Regional Setting: English)
System Manufacturer: To be filled by O.E.M.
System Model: To be filled by O.E.M.
BIOS: BIOS Date: 10/20/10 09:47:36 Ver: 08.00.10
Processor: AMD FX(tm)-8150 Eight-Core Processor (8 CPUs), ~3.8GHz
Memory: 32768MB RAM
Available OS Memory: 32712MB RAM
Page File: 6905MB used, 45806MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: The file aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
Display Devices
Card name: ASUS ARES2
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x6798)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV_6798&SUBSYS_99991043&REV_00
Display Memory: 22114 MB
Dedicated Memory: 6014 MB
Shared Memory: 16100 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: VX2770 SERIES
Monitor Id: VSC3A2C
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1151 (English)
Driver Version: 9.2.5.0
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Driver Attributes: Final Retail
Driver Date/Size: 1/10/2013 11:51:00, 1120768 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
Device Identifier: {D7B71EE2-24D8-11CF-8C77-93B9BEC2C535}
Vendor ID: 0x1002
Device ID: 0x6798
SubSys ID: 0x99991043
Revision ID: 0x0000
Driver Strong Name: oem2.inf:cb0ae414ff1c3ccf:ati2mtag_R575:9.2.5.0:pci\ven_1002&dev_6798&subsys_99991043
Rank Of Driver: 00E00001
Video Accel: ModeMPEG2_A ModeMPEG2_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeVC1_VLD
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
yu0307
The latest report is, when i play the COD BOp2, this error came out and shut the application:
atidxx32.dll
xeromist
Well, here's a free option if you feel up to it: Download an Ubuntu Live CD and boot into that. It doesn't require any installation as it will just boot off of the CD. Then load up Youtube and see what happens. This completely eliminates Windows and the drivers as a possible cause without having to actually install a whole new OS. If it still happens then you know it is somehow hardware related.
