01-23-2014
07:04 AM
- last edited on
03-05-2024
08:01 PM
by
ROGBot
07-21-2014 07:05 AM
07-21-2014 10:46 AM
07-21-2014 11:00 AM
Dejan99x wrote:
This looks good.
Regarding voltage reading I'm not sure if voltage on this slider is correct. You can also check voltage in afterburner monitor on the right side. If memory voltage is not visible, you can enable it in settings. How much is it?
07-27-2014 02:14 AM
wilflare wrote:
anyone else got a E3Y? hmm seems like the E5Y cards are doing fine.
guess I might have to push for a 770GTX 4GB instead
Dejan99x wrote:
If you have issues, just ask for refund and buy something else, if possible. This is the easiest option. Good luck to all of you.
07-27-2014 08:48 AM
I was wondering: Did anybody try to flash the 280X DCII (non TOP) BIOS to TOP edition?
Removed the heatsink, cleared all traces of thermal paste from the GPU and re-applied
07-31-2014 01:00 AM
07-22-2014 12:51 AM
07-23-2014 03:43 AM
07-23-2014 03:58 AM
Anzejk wrote:
Hi all! 🙂
Soo... I've been watching this thread for quite a while, searching for a fix for this GPU mess and i finally decided to make an
account here.
I have R9 280X DCII Top batch E3Y and while i get no "real" artifacts i sometimes get a black square somewhere on my screen
and it's really annoying.
The only thing that somewhat worked for me was OC'ing the GPU memory by 25mhz to 1625mhz. When i lower it to 1500mhz
i noticed that black square appeared a lot quicker than with default mem freq. so i tried oc'ing it a bit and it takes a lot longer
for the square to appear, if at all. Weird, right?
I guess the memory voltage really is too high. It sure looks like it. When i tried oc'ing GPU mem by 50 mhz the black scquare
was gone but some games started artifacting after somewhat longer play sessions.
I was wondering: Did anybody try to flash the 280X DCII (non TOP) BIOS to TOP edition? I think the non TOP version doesn't
have this problems because the mem is at default speed and voltage. I wanted to try it but i'm really afraid of doing it cause i
searched the net but didn't find any thread about anybody trying it so i really don't know what would happen.
Maybe it would work? It should work, right? It's the same card only with lower clocks?
ASUS, please fix this mess!!! Lower the goddamn memory voltage to 1.5 or 1.55 so people could at least downclock the
GPU memory and somewhat fix this!
