currently they are wired as per Advertised on the Card micro site
http://www.asus.com/Graphics_Cards/AMD_Series/HD7970DC2T3GD5/
here's the configuration
EAH7970 ___________________________ VS247H-P
DVI-D ------------------------------------------> HDMI
DisplayPort ----------------------------------> HDMI
I choosed to use HDMI on the other side for easier cable management through the inner tubes of the 6 monitor mount
(the picture doesn't make it justice, the real thing is super sturdy and of very fine quality build, with very nicely done hollow tubes to run the cables from the inside), because the DVD-D connector is too big to fit through the holes of the Hex Monitor mount.
Running Win7 x64 with 12-3 catalyst drivers
maximum i can only manage to power on 4 monitors, but windows only lets me use 2 monitors at a time
it's having trouble detecting the 6th monitor, the 5th monitor i need to change another cable as it seems like a cable issue with #5
but regardless of that It should at the very least let me use my 4 monitor if i physically disconnect the cables on the other 2 problematic ones, yet Win7 will still not let me use more than 2 monitors, so what's the deal with that?
If i go to Screen chooser in Win7 or from Within Catalyst Desktop Manager, all 5 monitors shows up, but it wont let me use them all, not even as separate desktops.
i can do a combination of 2 anything
2x DVD-D or 2x DP, or 1 DP + 1 DVD-D
but it wont let me use all 4 at any given time
😞it's been driving me nuts for the past couple of days
I want to enjoy my new rig, but can't do that until i get this thing sorted out.
I just got hold of 4 DP to DVI-D just for troubleshooting shakes, but i'm sure it won't make any difference.
so, the new setup will be:
DVI-D ------------------------------------------> DVI-D
DisplayPort ----------------------------------> DVI-D
And if you must know, the tiny Switch in the video card it's set properly to the "Left" to allow the use of DP + DVI-D instead of "Right" which only allows Dual link DVD-D as per factory default.
I'm I missing something on the software side?
Any help or ideas will be very much appreciated
i7-3970X, Corsair H80, 32GB G.SKILL, ASUS RAMPAGE4 Formula, ASUS VG278H(3x27") & 3D Vision2, EVGA GTX 690(2x) 5760×1080*3D, OCZ ZX 1250W, OCZ 256GB Vertex4(2x), Seagate 3TB(6x), Antec LanBoyAir, Logitech G510, G600 & Z560 THX, Sennheiser PC163D, TrackIR5, Thrustmaster T.Flight Hotas, Saitek PZ35
