Fan on second card not going above 20 %
wolfy
R290 ROG Matrix Platinum when running in Crossfire i notice the second Cards fan does not go over 20 % its not the Card as i have changed them around and the results are the same
Useing drivers 14.12.
also any idea what bios they should be on ?
ROG MAXIMUS XI FORMULA
CPU: Intel 9900K @4.7 ghz
2 x Corsair Vengeance RGB PRO DDR4-3200
C16 BK DC - 16GB
1 x Aurous 2080Super 8GB
1x 500GB Samsung 980 M.2 NVMe
1x 500GB AData 8200pro M.2NVMe
2 X 500 GB SSD
1000w PSU from corsair
Tower Lian Li PC-O11DW Dynamic
1 x dell 34" curved + 1 x 24"
CPU and Motherboard.
NZXT Kraken X73 RG
Ipswicher
My card's temperature sensor was dead, so my local dealer changed it for me.
I'm not sure whether the second card needs to have fans going at the same rate as the first.
Remember, the second card is an add on, and only has certain duties to preform, so the sensor may be OK.
The second card does some things, but not all things, for you use the" ports" on the first card.
That is where the performance is sought.
