ROG STRIX X870a USB audio bugs, issue with Astro Mix-Amp Pro TR
J_Undead
So, I have a ROG Strix x870a paired with a 9800x3d. I don't really have any issues other than my audio is bugged. The mix amp splits audio into two streams, game and voice. It plugs into a USB port, I've tried every port as well as the front panel. Audio works fine if I plug my headset directly into the front panel AUX. Whenever both audio streams have input at the same time my audio is just completely muted and doesn't work. I've updated my bios, all of my drivers and can't figure out what's causing this, other than maybe incompatibility with the drivers? I've seen one other person with the same issue but nobody had commented on his post. I don't really know all too much so I'm lost as to what's causing this.
Would it be worth it to just deal with it and hope a bios/driver update fixes this issue, or just play my luck with mobo roulette?
IWafflesI
I am having this exact same issue on my mixamp on a asus x670e-e paired with a 9800x3d. Were you ever able to find a solution?
IWafflesI
***EDIT*** Problem came back again 😔
