X670E-Plus - RAM Debug LED - after working fine for a few months.
kosteczki
First built system in Dec 2024
X670E-Plus Wifi
AMD Ryzen 9 9950x
MSI Geforce RTX 4060 ti ventus 2x black
DDR 5 Kingston Fury Beast (1x16)- KF556x40bb-16
Mag A850GL power supply.
Liquid Cooling
Could not get the system past Ram Debug LED, finally exchanged the motherboard for the same, re-installed everything and it worked fine.
Been running no problem for 6 months now, then crashed while kid was playing a game.
Won't boot passed the Ram Debug LED, monitor shows no signal (tried in both gpu and onboard hdmi).
- Re-seated Ram - no change.
- Cleared CMOS - no change
- Flashed Bios to newest version - no change
- Re-seated everything from CPU, GPU, Ram cleared CMOS again - no change
Maybe ram is faulty...all I could get is a 2x16 so ..
- Installed DDR 5 Kingston Fury Beast (2x16)- KF556x40bbk2-32 into A2 and B2 - no change
- Cleared Cmos - no change
Still cannot get signal to monitor or past Ram debug LED.
Anything else I can do here ?
I now have an open RMA, but kid is anxious to get PC back, figuring RMA might take forever so honestly thinking of just dumping asus and moving to a different brand all together
Any advise?
5 REPLIES 5
mdzcpa
Level 12
How long did you leave the system for RAM to train?  Sometimes the initial training takes a very long time after a clear cmos.
Higm94
I'm experiencing the exact same issue. What has worked for me is completely disconnecting the power for at least 6–8 hours. When I plug the power cable back in, the PC initially gets stuck on the yellow LED, but after pressing the power button again, it eventually boots successfully.
In my case, I also tried updating the BIOS via FlashBack in case it was a BIOS-related problem. However, after the process completes, the screen shows "Updating BIOS" and it never finishes. If I disconnect the PC from power and wait around 6 hours, the message appears again on the next boot, but it gets stuck on the yellow LED. After restarting manually, the system boots normally.
For me, it definitely seems like a cold start issue.
Hope this helps you too.
x670E-I Gaming Wifi
7950x3d
32 GB Crucial PRO DDR5
4070tisuper
Silent_Scone
Super Moderator
Hi see post below.
Understanding Memory Training on AMD AM5 Motherboards (Q-CODE 15 & Yellow DRAM Q-LED)
If behaviour persists, consider remounting CPU and memory (appreciate you have already tried most steps).
Inspect CPU pin-pad and socket for any debris or damage, then remount, ensuring for consistent mounting pressure as per cooling vendors guidelines.
If behaviour persists further, contact service for your region.
Tarvoskemwer
Had a similar issue at one point, had moved the pc during the holidays and it wouldn't boot when I got home and plugged it in. CMOS reset didn't work etc.
The weird fix was that I had to remove one ram stick, then the pc would boot.
Then I could power down and insert it again, and it's been running fine ever since.
