ROG STRIX B650E-I front audio panel doesn't output audio
hanni5bal
Hey everyone
I have a FRONT panel audio output problem with my new ASUS ROG STRIX B650E-I GAMING WIFI , and I'm pretty sure it's a driver issue, because when I plug in my headphones, I get the notification from Sonic Studio and it actually recognizes the audio jack connection, but I can't hear any sound from that. I tried multiple devices and result is the same. Back panel audio ports work correctly, but something weird with front panel.
I want to connect my desktop speakers to back panel and my headphone wire to front panel and change the audio output whenever I need.
Here are my PC specs:
PC Case -  LianLi DAN A4-H20
MB - ASUS ROG STRIX B650E-I GAMING WIFI
CPU - AMD Ryzen 7800X3D
RAM - G-Skill 64GB DDR5
GPU - Zotac 3090 24GB
Windows 11
Audio driver version - 6.3.9600.2328 from ASUS official MB drivers
I tried to reinstall drivers from several sources, but nothing helped for now.
Please help me to find the solution, or maybe there is a specific driver I should install to make my front audio panel output sounds!
Thank you
hanni5bal
Upd_1
I updated my BIOS from 1616 to 2611
And right after bios update it also automatically updated some firmware before booting windows.
Then I tried to install drivers from this post: [DRIVERS] Realtek USB Audio (AMD 5xx/6xx/TRX40 & I... - Republic of Gamers Forum - 845528 (asus.com)
Unfortunately, the problem still remains, I can't hear any sounds from headphone front panel jack! =(
