ROG Strix B650E-F Gaming Wifi No Signal red LED
RogerKings25
Configuration:
Placa Base: ROG Strix B650E-F Gaming Wifi
Procesador: AMD Ryzen 9 7900X
Memoria RAM: Fury DDR5 6000MT/s 36-38-38 32gb EXPO/XMP
Hello colleagues.
I have a problem and I don't know how to solve it. I'm new to this field and I'm asking for your support and knowledge to see if I can solve it.
When turning on the motherboard, the DRAM LED (yellow) turns on for several seconds and then the CPU LED (red) turns on and two short beeps are heard and nothing happens, there is no video signal.
I've already tried changing the memory, reseating the processor, checking that there's no damage to the pins on the processor socket, and everything's fine.
I appreciate any support or ideas to help me solve this problem. I've been at it for several days now and I'm running out of options.
1 ACCEPTED SOLUTION
Accepted Solutions
Hello Nate152
I appreciate your support. I'm telling you that I performed the BIOS update and it's now working correctly. I was late in responding because I was trying to find a USB drive with an activity LED to see if it was actually updating. Now I have the problem with the drivers, which are making it difficult for me to update, but that's a different topic. If I need help, I'll post about it.
Thank you so much.
4 REPLIES 4
Nate152
Hello RogerKings25
Try this:
1) Shut down your pc and unplug the power supply cable.
2) Take out both sticks of memory.
3) Install 1 stick of memory in the A2 slot (2nd slot from the cpu).
4) Clear the cmos by shorting the 2 pins with a metal object such as a paper clip or small screwdriver for 5-10 seconds.
5) Try starting your pc.
Hello Nate152
I've tried several times, including removing the CMOS battery, but with no positive results, it's still the same.
Nate152
Ok, sorry to hear that didn't help.
Next thing to try is updating the bios.
You can do this with the bios flashback feature. If you need help updating the bios just say so and I'll list steps how to do it.
Hello Nate152
Thank you so much.
