11-07-2025 04:24 AM
Is there any way to flash JUST the LED EC firmware? I've had absolutely zero working Aura lights all year and the last post was useless since I was directed to use the armory crate log form, which I don't use armory crate, and the LEDs were non-existent outside of windows. This continues to be the case even on the latest bios. No matter what setting I enable or do, they remain off at all times (THIS IS NOT A WINDOWS ISSUE). When I updated to the latest bios to fix some instabliity issues which crossing my fingers are actually solved, I noticed the LED EC version in the bios is completely missing. So I suspect either it's corrupted or completely dead. Since v3112, which I did install as I've installed every bios update in hopes of resurrecting the lights, you cannot rollback anymore. So how do I flash the LED EC if I can't use an old BIOS update which includes the firmware?
11-09-2025 11:16 AM
Does genuinely no one from ASUS care to have any input how you flash a non-rollback compatible bios to flash firmware that only comes bundle in bios updates? Really? I've been reading the manual and it's not clear if the secondary bios is flashable. If I could power down, swap to the secondary bios, flash it with 2904 which is the last bios to include the EC firmware, then those chips could get flashed and I could go back to the main bios with potentially fixed chips. Can someone at least confirm if this is doable?
