Crosshair x670e extreme (collect system info lag stuttering)
DioEsiste
Hello all, I hope someone can help me... New PC just assembled specifications:
-asus crosshair x670e extreme
-7950x
-gskill 6000 cl30
-4090
-loki 1000w platinum
-ekwb liquid cooling
-windows11
basically when I start monitoring programs like cpuz hwmonitor armor crate it makes a lot of lag the cursor stops and from numerous slowdowns, only and excusically with programs like that, if I play or something else everything is perfect.
I do a clean install and it starts giving these problems when I reach the latest windows 11 updates and install the thunderbolt driver folder.. you notice the slowdown when cpuz and hwmonitor (they take information from PCI in the case of cpuz around 10% of the load) can anyone help me please?
Thank you
AMD 7950x with EKWB Quantum Magnitude Flat Coldplate Direct Die | Asus x670e Extreme | Gigabyte Aorus 4090 (@ Power Limit 80 Gpu Clock 2465Mhz Boost 2780Mhz Memory 1500mhz Gpu-z Info) | 32GB G.Skill Trident Z5 NEO CL30-38-38-96 (@ CL28-36-36-36 1.35v) | 990pro 1TB x2 Raid 0 | Asus Loki 1000W Platinum | Samsung Odyssey Neo G8 240Hz Curved 32"| EKWB custom loop water cooling
DioEsiste
can you delete i moved to the right section, sorry
VirtualDJ
this is a problem between "asus". on the thunderbolt disable the option "turn off this device to save power" in the device manager (i discovered this problem by helping a friend who had the same problem).
I think ASUS is already aware of this problem
