02-11-2023 12:46 PM
04-16-2023 08:49 AM
Hello,
The latest bios (1101) was released five days ago, give it a try if you're still having issues.
04-16-2023 09:03 AM
Thanks Nate I was already running the latest bios in the hopes it might solve it and was still seeing these events. I changed the c states to enabled and I actually forgot I'd also changed "medium load boostit" to enabled and I've had zero events since.
04-17-2023 11:05 AM
You're welcome
I've got the kernel power 41 before and I know this came from event viewer.
It shows because your pc didn't shut down correctly for whatever reason.
Great to see you were able to fix the kernel 41 power error by enabling C-states and enabling medium load boostit.
Thank you for providing your solution, this may help others.
04-17-2023 04:36 PM
Thank you for stating your solution. This could help others as well.
04-18-2023 12:23 PM
please help me with this. my laptop constantly powers down and boots back up. it does not go through a normal restart sequence. the issue started out of no where. i have a g512LU, and im running windows 10, this is after a hard reset and installing fresh windows, it was 11 previously and the issue continues in 10.
i am very desparate for answers,my laptop is only 2 years old and i have tried borderline everything.
my event viewer only gives me a critical kernel 41 error each time it crashes and nothing else.
few things ive tested with no luck are: biosupdate, flashing the drives, my asus diagnosis, new m.2, new ram, running it on only the adapter with no battery. nothing has worked. the closest thing to working was when i changed what the power button does, i then got a good ~8 hours out of it before it started again. now i get anywhere from 5mins~1hour with the laptop and it is completely unpredictable. sitting idle, in game, watching youtube, even when its asleep with the lid closed it happens. ive run it with only the ms services and still no luck,uninstalled armoury crate as well. no luck at all. during the time i have typed this post on my phone the laptop has gone through 4 reboots and this is all without me even opening a file. it simply starts up , goes to home page, ~reboots after some time, and repeats
please please help me out , i desperately need the laptop to work and its putting me in a very bad spot, any help is appreciated :\\\
04-18-2023 12:38 PM
@livedukk , try entering bios, then enable "C States" and "medium load boostit" . You can search for these at the top. That's what seemed to help me anyway. I've had one reboot in the last few days instead of a handful per day.
04-18-2023 12:47 PM
i cant seem to find the search option, or the individual options themselves. im on version 314, the cstate or load boostit settng doesnt seem to be there in the advanced mode or EZ mode. is there something im missing ?
thank u so much for the response btw 👍
04-18-2023 02:10 PM
04-18-2023 08:24 PM
Ah ig this is a different bios, mine doesnt have those options. is there any other way to enable the instructions you provided ?
05-02-2023 01:01 PM
I use 7950x3d and B650e-e and meet the same issue. It happens after updating bios to 1413 and 1414beta, revert to 1409 fix this issue for me.But I'm not sure if I should continue to use this old bios, according to some reports in the past few days this bios has security issues that could burn your cpu
