02-11-2023 12:46 PM
03-16-2023 07:05 AM
03-24-2023 05:47 PM
Oddly, I was having exactly the same issues as OP. Disabled C-states in the bios and haven't had a kernel crash since then. Some random threads have commented that this could mean I have a mildly defective CPU that can't throttle back up out of C6, but without buying a second CPU, I can't test whether a new one fixes the issue.
04-14-2023 11:13 PM
Set minimum CPU usage to 5% in the power settings.
03-02-2023 11:05 PM
04-13-2023 06:52 PM
Hi all, also new here. Having the exact same issue as everyone here. My setup is as follows:
Windows 11, fully updated running High performance power plan.
AMD 7950X3D, overclocked using PBO and curve optimizer
ROG Crosshair X670E Hero, Bios 1101
Dual Gskill 32GB RAM, f5-6400j3239g32gx2-tz5rk, running DOCP profile 1, overclocked to 6000
I can confirm it's been happening for about a week for me now, just random reboots with no BSOD. I have none of these kernel events prior to about a week ago and had already been running overclocked for at least two weeks prior to that.
I'm curious what everyone's power plan is because about that time, I believe I'd been messing with power plan options?
04-14-2023 02:22 AM
Just to share my experience about something similar that happened to me last year. I had EVGA RTX 3080 FTW Ultra and PSU Corsair RM 850x that were happily running together for two years, until all of a sudden BSODs and reboots started. Sometimes I managed to play a game at the lowest settings for an hour without an issue, sometimes the reboot happened immediately after launching the game. Once or twice the PC rebooted on the desktop. After I replaced the PSU with RM 1000x everything fell into place. Later I read that GPU and CPU may have power spikes for milliseconds that are enough to throw the PSU off the rails if it is not stable enough. And in my case I had used this PSU for two years with the same hardware before it started to fail me so there is no guarantee that something which has worked before will continue to do so.
So, in my opinion, it is possible that the reboots in your case are caused by similar power spikes from the GPU/CPU and the PSU cannot handle them. It may be also due to faulty components on the motherboard that must deliver stable power supply to the components but I have no experience with such issues, thank God.
04-14-2023 09:09 PM
I may have accidentally fixed this issue by explicity enabling c states in bios. In my case, it appears the event would occur under minimal load not under high load as some have mentioned. Give it a shot. I went from 4ish events a day to none.
04-14-2023 11:16 PM
C states should be enabled by default.
04-15-2023 07:23 AM
Yes agreed, it was set to auto previously but I haven't changed anything else and I've now had zero reboots in the last day, normally hitting 4 or more. Then after rereading this thread saw other people had seen similar results from enabling or disabling so maybe this wasn't quite implemented correctly by the bios team.
