B650M BIOS Fan Speed Control
frogon
I have a new build with ASUS B650M-PLUS inside a Lian Li A3 with a CPU fan and one case fan plugged into CHA1. I set the fan speed inside the BIOS and it seemed to work at idle, but many times both fans will go to significantly higher percentages than they should be at based on the temperature. It appears that it is running off CPU usage and not CPU temp. This is somewhat fine because it is keeping the CPU temp lower than the fan curve, but I'd like to know what is controlling the fans. I'm running Windows 10 with no extra fan controller software.
These are my fan settings in BIOS and then hardware monitor log (Fan #1 is cha1 and Fan #2 is CPU) #. You can see CPU temp was 34F and CPU Fan was 55% and CHA1 was 49%. According to the curve the expected fan speed is about 30% and 12%, significantly different. What is causing the fans to not follow the curve set in the BIOS
PXL_20250207_005028140.jpgPXL_20250207_004955187.jpgfan usage low temp 2.png
1 ACCEPTED SOLUTION
Accepted Solutions
gupsterg
Level 15
Don't use HWMonitor on Ryzen, it is not good, it hasn't been since 2017. Use HWINFO, link.
Fan setting Step up you want on higher level, so when CPU temperature spikes the fans do not ramp up quick.
On the rise and fall of the clock cycle...
5 REPLIES 5
frogon
adding a little more data to this thread. Below is a data log of both fan speed percents and cpu temp. You can see the cpu temp stay the same and both fans spool up considerably when I opened up Steam and iRacing at the same time. based on the fan curves in the bios I expect since the CPU did not increase in temp that the fans would also have not increased in speed.
kfo1pCt
gupsterg
Level 15
ahhh okay thanks! I got HWInfo and I'm seeing the cpu temps spike up under load and the fans are speeding up to match. Makes a lot more sense now. Thanks!
gupsterg
Level 15
No problem 🙂 . In HWINFO you can also set polling interval, I use 500ms as default 2000ms is a bit slow for my liking.
chemie
The CPU maybe higher temperature but not producing a lot of heat so there is no need to ramp chassis fan to 100%.  The case air is no hot.  Chassis fan is more important to GPU load vs CPU temperature.  This will keep noise down
