08-23-2024 10:28 AM
I’m building my very first pc, bought the Asus rog strix b650-a motherboard and a msi mpg a650gf, about to finish the building I was missing the proper conector. It looks like this ( ) [][] () in the motherboard, but the cpu cable that the power supply has looks like this: ()()()[]
should I buy another power supply? And if so, what adapter should I buy for an Asus 4070 super dual in case the new power supply doesn’t come with the cable don’t know much
Solved! Go to Solution.
08-23-2024 06:19 PM
Yes, the cpu power cable will work just fine.
Your power supply comes with a 12VHPWR cable for your ASUS Dual RTX 2070 Super, you won't need to use the power adapter.
Yellow - CPU power cable
Red - 12VHPWR cable
08-23-2024 02:45 PM - edited 08-23-2024 02:45 PM
Hello Alejandroh12
You'll want to connect the 8-pin cpu power cable and 24-pin main power cable.
The 8-pin cpu power cable is usually marked ATX or CPU, it could also be a 4+4 power cable.
The ASUS Dual RTX 4070 Super comes with an adapter in the box, ASUS recommends a minimum of a 750w power supply.
What power supply do you have?
08-23-2024 05:26 PM - edited 08-23-2024 05:30 PM
The cpu cable looks like this, would still work?the psu is corsair rm750e
08-23-2024 06:19 PM
Red - 12VHPWR cable
