Asus b650e-f strix wifi problem with dram high voltage mode
hasandoel2
asus b650e-f strix wifi
r9 7950x
gskill tridentz 64gb ddr5 6000mhz cl30-40 (richtech pmic status false/unlock)
this is the bios setting:
1. high dram voltage = enable
2. set vcc vddqq = 1.5v
3. Advance memory voltage :
- pmic force continuous = enable
- pmic volts = sync
4. save settings
the result is: can't save the settings,,,from several attempts only 1x can be saved. hwinfo64 also reads 1.5v, but when the pc shuts down and restarts, the settings are not saved again.
is this bios bug or how to enable high dram volt mode?
thank you
0 REPLIES 0
