05-10-2017 02:14 AM - last edited on 03-05-2024 10:05 PM by ROGBot
05-10-2017 06:16 AM
Waza88 wrote:
Crosshair 6 Hero has an input for liquid temperature sensors, is it possible to run fan profiles from this data alone?
My Ryzen 1700 is running too cold 😄 I am having a lot of trouble getting proper fan response in relation to the loop temperature.
I also have two R9 290s in the same loop and this makes this issue worse since some games are really heavy on the GPUs while my CPU is barely braking a sweat.
I don't like to run software based solutions so I really really would like to have BIOS based fan curve.
05-10-2017 06:46 AM
05-10-2017 09:48 PM
entropic-remnants wrote:
That would require the mobo to have an input for a coolant temperature sensor. There doesn't appear to be a place where that could be done on the Crosshair VI
05-11-2017 05:24 AM
05-11-2017 05:38 AM
05-11-2017 08:12 AM
Asus121 wrote:
Great post now my question is when i use asus ai suite 3 i see water in temp water out temp but no flow speed is that only available in bios or is there another program we can use from asus that will give me all the input meaning water in water out and flow speed not just water in and water out like asus suite 3
05-11-2017 10:03 AM
Krayn wrote:
You have to set the CPU fan to Water Cooler (you can choose CPU FAN or Water Cooler when assigning the FAN Position). If you click on the CPU Fan now there is a display for flow.
Also i just noticed in the FAN section at the bottom right there is WATER_FLOW aswell.
05-11-2017 10:57 AM
Asus121 wrote:
Can u post a screen shot of the in windows water flow
05-11-2017 11:19 AM
Krayn wrote:
i dont use a flow sensor in my loop but sure.
(marked the two spots where the flow is shown 🙂 )
