Strix B550-F Gaming (Wifi) stuck on DRAM led, BIOS flashback not working
infinipix
Hi
I bought a used B550 board but I can't get it to POST. The yellow DRAM led stays on.
I have tried BIOS flashback both with and without a CPU but the led is not even lighting up.
I got it to sort of POST once when I was fiddeling with a pc speaker to try to see if there were beep codes, then the POST leds were lighting up and stayed on VGA and BOOT. I had no GPU installed at the moment so I turned the power off and connected a GPU thinking that the flashback might have worked after all, but I was just back at the DRAM led again.
Any suggestions?
I've tried with both a 3200G and a 5600X, both known working and a stick of Corsair 8GB RAM that also is known working (In all slots)
Regards
chains74
Hi infinipix,
try putting the ram into a different slot and also is the ram a lower mhz? sometimes the processor likes a higher speed ram
I took 12 years off of owning and gaming on a PC,
I'm back with vengeance
Gamer Rig
ASUS ROG STRIX B550-F Gaming WI-FI II MoBo
AMD Ryzen 7 5800X3D 8 Core AM4 CPU
ASUS ROG STRIX GeForce RTX 4070 Ti SUPER OC 16GB GPU
ASUS ROG Strix Aura Edition 850W 80+ Gold Fully Modular PSU
64GB Corsair Vengeance LPX Black (2x32GB) 3600MHz DDR4 RAM
1TB Corsair MP600 PRO NH NVMe PCIe 4.0 SSD
be quiet BK007 PureRock2Black CPU Cooler With CoolerMaster Halo120mm Fan
Secondary, Server, Streamer Rig
ASUS ROG STRIX B550-F Gaming MoBo
AMD Ryzen 5 5500 6 Core AM4 CPU
MSI GeForce RTX 3050 OC 2X XS 8GB VENTUS GPU
AeroCool Integrator Gold 750W 80+ Gold Fully Modular PSU
16GB Corsair Vengeance LPX Black (2x8GB) 3600MHz DDR4 RAM
1TB Western Digital Black Pro NVMe PCIe 4.0 SSD
CoolerMaster Hyper212 Halo² CPU Cooler With CoolerMaster Halo120mm Fan
Hi @infinipix
1. Clear CMOS via the button on the rear IO panel.
2. Insert 1 DRAM Module into slot A2
3. Reseat the CPU and cooler and inspect the socket and CPU pin-pad for any debris or damage. Ensure even consistent mounting pressure. as per cooling vendors' instructions.
4. Retest and report back
