I am having problems connecting the 2 x 4 pin connectors from my Corsair HX650 power supply to the 8-pin 12V connector (EATX12V_1) on the RoG X570-E motherboard. It just doesn't seem to have enough room for the two connectors to sit side by side, and I don't want to force them in.
I am sure that the plugs are oriented correctly.
Does anyone have any ideas or do I just need to give it little bit more force?
Thanks in advance.
James
