05-02-2018 11:27 PM - last edited on 03-06-2024 08:32 PM by ROGBot
07-02-2018 06:43 AM
WilVidz wrote:
I'm really having a rough start on my new build.This is my first AMD build and I really could use the help. LOL
I am not able to get anything on my monitor when I hit the start or power button.So I can't even see or use UEFI/BIOS.
I am getting Q-Codes d6 and then 0d about 2-3 secs later, it also seems that it just hangs on 0d with both the white(VGA) and green(BOOT) LEDs lit up right under. Also sometimes it would reboot and do the same process and hang on Q-Code AE with only the white(VGA) LED lit up.
Things I have done/tried.....
Tried BIOS Versions 0207,0401,0509 and 0601 using USB Flashback with a FAT32 USB 2.0 Flash drive.
cleared CMOS many times with different BIOS.
I tried single, dual and quad dimms. single using slot A2, dual using slots B2 and A2 and lastly using all dimm slots.
Reseating many times.
Tried moving my gpu to different PCIeX slots. Unplugging and replugging the power connectors on PSU and GPU sides. Also swapping and even used different cables.
I even tried using all ports on the GPU(DVI and HDMI). I have not tried the Display port because my monitor doesn't have one.
Tried a different GPU(Same type, because my old build was SLi)
Tested out and moved both GPU's back to my old build and both work with no problems.
I even have tried 2 different monitors.
I just put in an order for a Asus ROG Strix RX580 just to see if this would work. If not i'll be giving it to my wife for her computer.
Here is my parts list.
AMD Ryzen 7 2700X
Asus Crosshair 7 Hero WIFI
G.Skill Trident Z 3200mhz (4x 8gb)
Nvidia GTX780 (Waiting for new GPU's to be released, Then I will upgrade. Kind of wanting to move to AMD for freesync/2.)
Elgato HD60 Pro (never installed yet, still in box.)
Crucial MX500 1TB SSD
WD Black 4TB HDD (never installed yet, still in box.)
NZXT Kraken X72 AIO
Corsair AX860i
Corsair LL120 Fans
Corsair K95 Platinum keyboard
Corsair Glaive Mouse
Acer GN246HL (no Freesync or G-sync)
Thanks in advanced for the time and help guys/gals.
07-02-2018 10:08 AM
07-02-2018 10:46 AM
