07-08-2017
07:17 PM
- last edited on
03-05-2024
10:12 PM
by
ROGBot
07-09-2017 09:07 AM
07-09-2017 09:24 AM
07-09-2017 10:24 AM
gupsterg wrote:
Hi, this is a low traffic site, so sometimes replies can be slow to come up.
Did you by chance remove the AM4 backplate?
Besides the Q-Code: 8 what are the Q-LEDs showing? ref user manual.
07-10-2017 03:09 AM
07-10-2017 08:48 AM
FuryA@ASUS wrote:
hi BlowUpDaChron
Code 8 Error is system agent , many purpose,
you may try reinstall, CPU , RAM for troubleshooting
just an advice try setting without OC then fine tune through AI suite 3
07-13-2017 11:41 AM
07-13-2017 04:42 PM
Nighter3D wrote:
Something that might be of use when you get a new board:
When i build or buy or diagnose any system i always try to run a set of stress testers. See if any component is doing well enough or if any has a risk of being a Dead-On-Arrival.
I would run this set in particular in Succession:
1) Memtest86. Make sure the memory is not defective.
2) Prime95. Put stress on the CPU, Motherboard and Memory. (dont forget to have something capable of reading the temps like HW Monitor or the AI suit). OCCT works too tough.
3) Furmark. Push the GPU to the thermal limit
4) Assorted benchmarks. Think Unigine,3DMark,AIDA64 and the likes.
I say this cause you used only OCCT by the looks of it, but that alone is not a reliable. Gotta go through the full set for thorough results.
Something to note about Ryzen too btw: Just because the memory is approved do NOT expect it to run at full speed. I got a 3200mhz set, but even with AGESA1006 i can run it at 2966mhz tops. Quite a few have made that mistake.
07-14-2017 04:20 AM
elguero83 wrote:
You should try to disable performance bias, that solved my q 8 problem.
