11-21-2019
05:39 AM
- last edited on
03-06-2024
07:23 PM
by
ROGBot
11-21-2019 06:16 AM
11-21-2019 06:27 AM
RedSector73 wrote:
Q Code 8 - System Agent initialization after microcode loading.
Basically it means CPU failure but it's cause can be anything.
(1a) Does your Enermax Liqtech II 280 have special backing plate & could it be shorting onto the board ?
(1b) or could it be too tight onto board ?
(2) Do you have from the CPU the RAM in Slots 2 & 4 ?
(3) Do you have power above the CPU on the left top motherboard plugged in (both sides if modular power supply)?
(4) Do you have anything plugged into the CPU fan headers ?
11-21-2019 06:32 AM
11-21-2019 06:59 AM
11-21-2019 02:21 PM
11-23-2019 07:31 AM
11-23-2019 07:23 PM
alucke23 wrote:
I got it running the enermax liqtech II 280 backplate was backwards. i turned it around, and it booted on first start, with the non QVL ram.
11-24-2019 02:29 AM
