Problem with chipset driver and x570
flaps
I take the rog crosshair exreme 2 week ago and all seem ok. if i controll in device manager all result ok. But if i go in detail in amd smbus -->general not appear the peripheric funciont correctly. Result no one driver is istalled for this device and in event the log show this:
device configured:
Nome driver: oem9.inf
GUID classe: {4d36e97d-e325-11ce-bfc1-08002be10318}
Data driver: 09/15/2022
Versione driver: 5.12.0.38
Provider driver: Advanced Micro Devices, Inc
Sezione driver: AMDSMBus64
Classificazione driver: 0xFF2001
ID dispositivo corrispondente: PCI\VEN_1022&DEV_790B
Driver prioritari: oem2.inf:PCI\VEN_1022&DEV_790B:00FF2001
Aggiornamento dispositivo: true
Dispositivo padre: ACPI\PNP0A08\0
Device not started:
Problema di avvio del dispositivo PCI\VEN_1022&DEV_790B&SUBSYS_87C01043&REV_61\3&11583659&0&A0.
Servizio:
Filtri inferiori:
Filtri superiori:
Problema: 0x0
Stato problema: 0xC00000E5
I istalled manuallly the driver chipset from asus site , from amd, clear all wih amd cleaner, reistallled windows11 ecc the result is the same.
The device function i also use taiphoon burner for test if the smsbus is active.
And for test i istalled also windows 10. the result is no one driver is istalled for this device but in this case the device manager not give error.
The same issuue give the amd pci: the device is report funciot correct but in event
Problema di avvio del dispositivo PCI\VEN_1022&DEV_1485&SUBSYS_88081043&REV_00\6&313998c&0&0040000A.
Nome driver: oem8.inf
Servizio: AMDPCIDev
Filtri inferiori:
Filtri superiori:
Problema: 0x0
Some one have the same issue? How is possible resolve (also seem function all)?
0 REPLIES 0
