Motherboard RGB LEDs no longer light up
Xeekk
After finally getting everything setup for my new desktop the motherboard lights all went out. I'm referring to the aesthetic RGB lighting on the board. I've toyed with all of the setting sin the BIOS related to this (there are 2 I believe) and I can't get them to come back on. They're never on. They worked for at least a day then quit. Eventually the RGB lighting on my AMD Wraith cooler also failed to come on, so now I have absolutely no RGB lighting at all. I've tried resetting all of the plugs for these to no avail. I'm not sure what could have happened since this all started well into the software portion of my build. I also updated the BIOS to the latest here on the forums (1001), but that did not help; though my fan and temps look more like they're supposed to thanks to it.
Everything works great right now except for the lighting. If I have to replace the board I will; for the price I really want EVERYTHING to work.
Any ideas? I've already sent a support ticket to ASUS, but no response yet.
40 REPLIES 40
jbasemoine
All light work but instead of the RGB STRIPS (bios 1701), also when i have AURA installed Ram crashes, at least windows is crashing due to some error's.
eventviewer keeps on reporting isseus with ram, this all stops when aura is unistalled, luckly settings keep being saved so the LED'S light up the way i want! (static heu 305)
