03-12-2020
03:24 AM
- last edited on
03-05-2024
08:01 PM
by
ROGBot
Edward_Teach wrote:
Version 1302 2020/03/0314.97 MBytes
ROG CROSSHAIR VIII HERO (WI-FI) BIOS 1302
1.Improved system performance
Before running the USB BIOS Flashback tool, please rename the BIOS file (C8HW.CAP) using BIOSRenamer.
Anyone brave enough to give this a try?
03-13-2020 04:18 PM
jimmycbl wrote:
i have issue booting into cosair vengence rgb pro 3600mhz c18. even Ryzen dram calculator cannot give the right values. even copied all the values into bios and does not boot. it just hangs. later i try from AMD Ryzen master instead
my system is as follows
Ryzen 3700X
MB Asus Crosshair hero VIII with wifi
Coolermaster water block
03-13-2020 07:17 PM
jimmycbl wrote:
funny thing is even with 2666mhz running, everything feels quite ok. no slowness nor stuttering or anything to prove otherwise. hmmm might leave it as it is
03-15-2020 12:24 AM
jimmycbl wrote:
serious everything except fb. every time video loads and there is a lag. so?
change the dram voltage to 3.7. It is the overzealous voltage of the mb that is kicking me to over 1.457 which is seriously wrong. i think 3.7v will push it down to acceptable numbers. later i check in bios again.
DAMN!!!!!
05-25-2020 10:09 PM
XIIIIX wrote:
How is your network connected?
Did you switch Ethernet connection and see the lag again?
With my CH8F the Aquantia was a big source of trouble.
Back to Intel and Steam, FB, Gaming etc is stable.
05-26-2020 04:47 AM
jimmycbl wrote:
it just hangs.
