07-27-2017
05:38 PM
- last edited on
03-05-2024
10:09 PM
by
ROGBot
07-27-2017 08:27 PM
Jackwolfskins wrote:
Hi guys , so ive just finished my custom wc build and pluged my pump to the W_Pump conector that aparently supplies enough watts to power my pump , i just can find any info on how that conector works.
Can i adjust the pump speed ? if so how ?
And will it turn the board of if pump rpm drops to zero , for example a pump malfunction.
And should i connect my rad fans to the CPU fan header ? Currently conected to Chassi 1 and 2 connectors.
Thanks in advance
07-28-2017 09:45 AM
07-28-2017 02:13 PM
Syaoran wrote:
The AIO Pump header provides enough current for most pumps. It does monitor the RPM of the pump, accurately is to be debated. You will want to disable Q-Fan completely for fans and the pump. This doesn't stop the motherboard though from shutting off the pump and fans for no reason. There is a thread about that mess if you happen to experience that issue. I have my rad fans, all 6 of them for my Arctic Cooling Freezer 360 plugged into a fan hub with that hub connected to the CPU Fan header just to monitor the RPM of the first fan on the hub. Some have resorted to powering their pumps through fan hubs or controllers because of the issue where the board powers them down for no reason at all, causing the computer to shut down because of high temperatures.
07-28-2017 03:09 PM
Do you know if same happens in the dedicated W_Pump header ?
Thanks for the warning on the aio_pump conector i have to use the other one because my pump draws 18w.
