07-29-2021 10:19 PM - last edited on 03-05-2024 01:52 AM by ROGBot
08-13-2021 09:09 PM
sc32valve wrote:
2 of 3 GPU fans? Really? That's a strange one for sure. The lights would totally make sense, but the GPU fans? Which GPU is this again? And what header do you have your lights plugged into?
08-21-2021 10:13 PM
08-22-2021 09:00 PM
08-23-2021 07:58 AM
08-24-2021 06:43 PM
08-25-2021 03:09 PM
09-02-2021 10:57 AM
BillBittel wrote:
My guess is it is a faulty PSU or PSU cable. The MOBO has to tell the PSU when to switch from its active ON state to its standby state. To do this, there is a PS_ON# control line between the MOBO and the PSU. When you shut down, the MOBO pulls PS_ON$# high to tell the PSU to switch to active ON state. The MOBO pulls the PS-ON# line low to tell the PSU to switch to the Standby state. It sounds like this is not happening, so the PSU is not going into standby.
So it does not turn off the SATA power outputs.
So, your Commander Pro (and CD Drive) are getting SATA power when they should not be.
So your fans are spinning and your LEDs will run whatever pattern is stored in the Commander Pro. Some patterns may not work because they require an active connection to iCue, but the more basic ones will.
So your CD drive is powered up.
This could be caused by a faulty MOBO, PSU, or the cable between them. If the PS-ON# line is open or disconnected, the logic input on the PSU will result in the PSU being in the active ON state. Since you swapped the MOBO, I suggest trying another PSU, or another cable. But before doing that, inspect the 24-pin power cable. The PS_ON# logic signal is on pin 16 of the 24-pin connector at the MOBO end (Google it). It may or may not be the same pin on the PSU end. PSU end pinouts vary with manufacturer and model. There is no standard pinout for that end which is why you should not use cables from any other brand or model of PSU unless they were specifically made for it.
If that pin is pushed in enough that its not making contact, or the factory crimp is bad, the PSU will never go into Standby so the SATA power outputs stay on. I think this is what is happening with your system. Worth looking into anyway.
https://powersupply33.com/atx-power-supply-pinout.html
Never seen this one before. Good luck!
10-18-2022 05:13 PM
Cujo159 wrote:
Thank you for your incredible insight and knowledge. I used all the new cables with the HX 1000i (and kept the cables attached with the HX 850i trial shown previously) but the one thing I haven't tried is switching out the MOBO cables. I'll give this a shot. I agree it has to be an issue stemming from MOBO power-down communications and commands but was shocked when a brand new completely different mobo didn't solve it.
09-03-2021 09:16 AM
09-03-2021 05:28 PM
