12-04-2020 11:35 AM - last edited 3 weeks ago by ROGBot
12-04-2020 01:03 PM
12-05-2020 11:20 AM
OldTechie wrote:
Assuming you run Windows, did you install the correct drivers? I use MoKiChU's drivers from this board.
Open the Realtek audio console and look for the microphone entry. You can set the amplification level to about +30dB.
Cheers.
12-05-2020 11:37 AM
BlueHawk0172 wrote:
I was just auto-updating for the drivers, I didn't select them but they were all up to date. I'm trying to download MokiChU's third party drivers now and I can't get the install to work.. - There's nothing to install, it only wants to open as a text document and doesn't give me the ability to run as admin
12-05-2020 03:29 PM
MoKiChU wrote:
You need to install 7-Zip (Free/OpenSource) to extract my .7z drivers packages (direct link to the latest version) : https://www.7-zip.org/a/7z1900-x64.exe
You have an ASUS ROG SS3|DTS Sound Unbound motherboard, so :
You need Realtek Audio Drivers (UAD - ASUS ROG SS3-DTS MB) from the first post of this thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
12-06-2020 12:57 PM
12-09-2020 01:51 PM
OldTechie wrote:
Now that you have the right drivers, open Realtek audio console and look for the mic entry.
You will be able to set amplify levels up to 30dB, doing so will solve your issue.
I posted this earlier also.
Cheers.
