C6H, problems with USB card on PCIEX4_3
Juanlo_
TL;DR: PCI Express USB card does not work on bottom PCI Express slot (rated at Gen3 4x on the manual). It works on secondary PCI Express slot, but then video card works at 8x.
I have a Ryzen build with the following components:
- Asus Crosshair VI Hero (BIOS 1403)
- Ryzen 1800X (default speed)
- 32 GB G.Skill DDR4-3200 (at 2133 Mhz)
- Samsung 960 Evo 512 GB (NVME M.2)
- 2 x Samsung 840 Evo 1 TB (RAID 0)
- NVIDIA Titan X Pascal (PCIEX16/X8_1)
Everything is working perfectly (I still haven't tried to clock my RAM at 3200 Mhz, that will come later), but I need a dedicated USB 3.0 card with independent ports for bandwidth consuming USB devices, so I purchased a Startech card with 4 independient USB controllers at 5 Gb/s each:
https://www.startech.com/Cards-Adapters/USB-3.0/Cards/PCI-Express-USB-3-Card-4-Dedicated-Channels-4-...
This card uses a PCI Express 3.0 x4 bus, so I installed it on the bottom PCI express slot, the one named PCIEX4_3. The manual says that plugging a PCI Express 3.0 x4 card disables the three PCI Express x1 slots, and I'm ok with that because I'm not using more expansion cards.
So I plug the card, attach the power connector to it and boot my computer. When Windows 10 starts, I get 4 new USB host controllers, that's correct, but Windows can't start these devices (code 10). They are named "Generic Host USB controller xHCI compatible" and they can't be started. By the way, Windows takes quite a while to load (it was lightning fast before plugging the card). So I try everything I can think of: remove the device from control panel, detect again, disable, enable, reboot... I even downloaded the driver from the card manufacturer, which is older and not meant for Windows 10. When installing that driver the card is recogniced as Renesas USB 3.0, but it still gets the alert icon and the Error Code 10.
65999
So I try to move the card to another slot, and I plug it under the grphics card, into PCIEX8_2, the slot meant for dual video cards, and then Windows boots really fast, as before, and the card is successfully recogniced as Renesas USB 3.0 host controller (4 of them) and it works fine. The problem of using this slot is that my graphics card is reduced to PCI Express x8, so I want the USB card on the other slot. I move devices again, and the problem happens again: card is recogniced as generic USB 3.0 that can't be started by Windows.
I tried to change PCIEX values in BIOS, there is an option to force that slot into x4 mode, but it does not help. The USB card simply doesn't work on the bottom PCI Express slot. As far as I know, this slot only shares bandwidth with the 3 PCIEX 1x slots so it should work fine if there are no more expansion cards.
Is my PCIEX4_3 slot defective? Any ideas? I'm willing to reinstall Windows, but don't know if it may help.
44 REPLIES 44
Raja
Not much else I can think of to test. Depends now if the QT team has a similar card that they can replicate with. If not, this may take some time or may be difficult to get patched.
Well, the card can be bought from Amazon and returned within a month once you have replicated the issue 😉
Just kidding, but seriously, I could send my USB card to you guys if that helps to accelerate the solution. Right now this PCI Express slot is completely unusable and I need it badly.
I wouldn't advise shipping it all the way to Taiwan and then back again.
Then let's hope they can replicate it somehow, if not with the same card maybe it happens with others. By the way, if you get some news about their progress, it would be great if you could post here about it. I know you are very busy, but I would appreciate it. Thanks!
Raja
It's in the system, so will have to see what the team says. Like I said, this may take a while to get a response for.
josh_b
Juanlo_ wrote:
TL;DR: PCI Express USB card does not work on bottom PCI Express slot (rated at Gen3 4x on the manual). It works on secondary PCI Express slot [...]
Welcome to my world. I have a NIC with the same issue. When is this going to get fixed, Asus. Getting a bit tired of this charade....
Juanlo_
Not sure what happened yesterday, but I noticed that 1 of the 4 Renesas USB controllers on the card was working under Device Manager, and it had been correctly identified as Renesas instead of generic. I plugged a USB device in each of the ports of the card until I heared the Windows sound of a plugged device, so I identified the working port and the USB device worked fine. Unfortunatelly, when I rebooted the computer, the controller stopped working and I have returned to the initial situation. However, this port is now permanently named "Renesas" instead of "Generic", although it still has an error with code 10.
I'll keep reporting if I find anything new about it.
Juanlo_
Although I wasn't expecting it, I just wanted to confirm that the issue is not fixed with 9920 beta BIOS. I hope the Asus engineers can make it happen soon in a future beta.
Juanlo_
If it's helpful to Asus... I tried a PCI Express x1 USB card from Innatek (single USB controller) in that slot ant it works fine. Apparently the problem happens when the card is 4x, like the Renesas wich has 4 USB controllers.
Raja
The replication request stipulates the need for the same card.
