11-23-2019 11:19 PM
02-01-2020 12:08 PM
Baio73 wrote:
Hi there,
I'm using a CH7HWF along with a LIAN LI 011 Dynamic XL case.
This case has a front led strip that should be compatible with Asus Aura:
I've connected the case's 3-pin cable to the ADD_HEADER1 of the mobo but still does not work.
Should I set something within ? Aura version is v1.07.71.
Thanks
Baio
02-01-2020 07:00 PM
christofalee wrote:
I will second this, I have the same case and the ASUS X570 crosshair and the case rgb lights are nowhere to be seen, I have to use the manual switch on the case IO
02-03-2020 06:26 AM
02-03-2020 06:51 AM
bluestang wrote:
I have the CH7 and was thinking about hooking the case lights from my Phanteks Enthoo Luxe Tempered Glass to the MB to control. After reading this, I think I'll just use the button on the case to control them to match what I chose for the MB in Aura lol
