ASUS ROG STRIX X570-F GAMING audio noise problem
Rob_Ainscough
When I use the RealTek onboard audio for this motherboard I get a lot of noise in the signal.  It's as if the audio circuits are not properly shielded.
As a test I used a MOTU M6 via USB-C port and the audio had NO noise at all, clean and clear.  So there definitely seems to be some circuit issue on this motherboard.  It's too late for a return but very frustrated with how ASUS seem to have design and quality control issues with their motherboards.  So much so, that I've started using MSI motherboards rather than ASUS.   What makes me even more positive this is ASUS design issue is that the MSI X570 motherboard uses the same RealTek and I get NO audio noise from it?
Anyone else have noise in their audio output from the onboard RealTek for this motherboard?
BIOS rev 4602 and RealTek driver version: 6.0.9411.1
Cheers, Rob.
0 REPLIES 0
