The Ryujin III 360 Extreme ARGB fans lights are off
amit2302
I have installed the Ryujin III Extreme and the fans are working, but the lights are off. I do not see the option for lighting affects in armory crate for the device and they do not follow the case fans. I checked all the cables and all are ok. They were working when when I first built the PC, but at some point they stopped working within a few hours
8 REPLIES 8
jweisturg
Same thing happened to me... fans have worked fine until today. Tried updating BIOS, reinstalling Armoury Crate, can't get them to come back online.
Aureliannn_ROG
Customer Service Agent
Hi @amit2302 @jweisturg ,
We sincerely apologize for the delayed response due to the recent holiday, as we were out of the office.
Regarding the issue you are experiencing, we would like to confirm the following points:
  1. Are you currently using the Aura Sync feature? If you use the lighting effects on the device alone, do they function correctly?
  2. Did this issue occur after updating any specific firmware?
  3. Please provide the Armoury Crate logs for our reference.
The log files contain detailed information about the software's operation, which can help our backend team identify the issue.
Please ensure that the logs accurately capture the moment the issue occurs. (Please enable logging, perform the problematic operation once, and then package the logs.)
Here are the steps to collect Armoury Crate log files: Please refer to Q5: What is APP Diagnostics? https://www.asus.com/support/FAQ/1043747/#a14
After completing the above steps, please upload the collected log files to a cloud storage service and provide the link along with the approximate time and method of operation for our analysis.
Also, please provide your product serial number.
We greatly appreciate your understanding and cooperation.
  1. I am using Aura Sync, however the case fans are all have ARGB working, but the ones on the Ryujjin III 360 Extreme are not.
  2. i had built the PC and the lights were working, however at some point they stopped. it might have been when i installed the driver for Ryujin III 360 Extreme in Armory Crate.
  3. Unlike Strix 4080 Super GPU, there is no option for lighting and there is no function for me to test the lighting on the Ryujin III 360 Extreme. Armory Crate Log
Where do I get the seria; number for the AIO?
Aureliannn_ROG
Hi @amit2302 ,
To confirm whether your cooler lighting can be synchronized with other devices, please help us with the following:
  1. Armoury Crate Devices: Please open the Armoury Crate software and check if you can see the "Addressable LED Strips" option in the device list.
  2. Lighting Settings: If you see the "Addressable LED Strips" option, please click on it and configure the lighting settings. Confirm that your cooler lighting is correctly configured and synchronized with other devices.
Since ARGB devices are usually displayed as "Addressable LED Strips" in Armoury Crate, please first confirm whether this option exists.
If you have any questions during the operation or need further assistance, please feel free to contact us.
I checked Armory Crate, I do not see "LED Strips" in the device list, however, I do see it under Armory Syncimage.pngimage.pngimage.png
Aureliannn_ROG
Hi @amit2302 ,
Regarding the Armoury Crate software lighting synchronization settings, if you need to adjust the water cooling lighting, please check the "Addressable LED Strips" option. This option is the name of your water cooling device.
In the Armoury Crate software, ARGB devices will be displayed as "Addressable LED Strips".
If you have any further questions, please feel free to contact us.
would there be an issue if the fans were attached to CPU fan and ARGB instead of chassis fan and ARGB?
Silent_Scone
Super Moderator
Hi both,
patch due after CNY, hopefully that will fix it. Ensure it's not due to MS Dynamic Lighting attempting to take priority.
