11-10-2018 09:21 AM - last edited on 03-06-2024 08:29 PM by ROGBot
11-12-2018 11:51 AM
11-30-2018 12:25 AM
mdzcpa wrote:
This is how I connected my RYUJIN 360. Yours should be similar:
Connect the RYUO fans to the RYOU fan connectors, not the motherboard
Connect the RYOU to the AIO Pump connector on the motherboard
Under AI Suite Fan Expert, RYOU Fan curve will adjust the fans, and AIO Pump curve will adjust the pump
If you do not have a AIO Pump connector on the motherboard, use the CPU Fan. However you will need to make sure you have set Q Fan or other UEFI fan control to disabled otherwise AI Suite will not be able to take control.
11-30-2018 02:23 PM
Gilgamessh wrote:
Hi , i have a Ryujin 240 and when i try to use preset on AI Suite (i have 4 preset) he put all the fans at the maximun speed.
Think i have some bios settings in conflict, where i can find Q Fan settings in z390 strix asus motherboard bios? thx
12-08-2018 01:45 PM
12-08-2018 03:40 PM
faxfan2002 wrote:
I've just check the RYUO on my system (several weeks after install!) and the AIO PUMP is in smart mode running at 100%, I assume there is no hard in running the pump at 100% (the system is not on 24/7 or anything - maybe a few hours a day)?
02-02-2019 07:46 AM
Gofran wrote:
please help i have two noctua fans connected to y but the fans keep going full what can i do provide picture or step by step please
