Ryujin keeps connecting and disconnecting and causes Hardware chimes
Crasje
Level 12
Hello,
Sometimes my PC starts hardware chiming for a minute +
When I look in Device Manager I found in the section Human Interface Devices an USB Input Device with a yellow exclamation mark. If I look at this device it gives me a code 10 (this device cannot start).
This is the device: Device USB\VID_0B05&PID_18AE\207E337C4B52, this is the Ryujin according to my Google search.
Any suggestions what to do anyone?
Cooler Master Silent Pro Hybrid 1300W ATX
Asus ROG Maximus Z690 Extreme
Intel Core i9-12.900k
ROG Ryujin 360
Corsair DDR5 Dominator Platinum RGB 2x32GB 5600Mhz
Samsung 980 PRO 2TB M.2 SSD (2x)
Seagate Firecuda 1TB
ROG RTX3080-O10G-Gaming
Monitor 1: ROG STRIX XG349C
Monitor 2: Samsung HDTV T27D590
ROG Claymore
ROG Spatha X
ROG Balteus Qi
Windows 11
Aureliannn_ROG
Customer Service Agent
Hi @Crasje ,
based on your issue, may I ask could you provide the screenshot that shows the error messege?
Have you make sure that your device firmware is at the latest version?
Whether the cooler can operate normally?
When did the issue occur? Have you make any change or update anything then the issue occur?
Hello,
Thank you for respons. See the screenshots from the device manager.
Running Armoury crate 5.6.10.0, it holds no updates for any of my ROG hardware.
The cooler runs normally. I have had this issue for a while, removing reinstalling did not solve it. I also had that my PC sometimes hardware chimes and I could not figure out why. I finally found out that it is the USB from the Ryujin that was causing it.
Currently the Ryujin is also not visible in AURA or in the Device list. FanXpert is visible and working.
I have been fighting with AURA, my motherboard and Ryujin for a while but only recently connected the Ryujin to the hardware chimes. Sometimes when I reboot, or when I turn off my pc completely, it will work again but never for very long. I hope you have any suggestions for me on how to tackle this.
Robert
ROG Ryujin 360
ROG Claymore
ROG Spatha X
ROG Balteus Qi
Windows 11
