Ryujin II Pump Speed Capped at 1770rpm
s09931
Hi, my Ryujin II pump speed is capped at 1770rpm. I can lower the speed and it is reported correctly, but if I put the speed at max in armoury crate, the max it will go to is 1770rpm. Isn't the max supposed to be 2800rpm?
PC Specs:
7950x
x670e Hero
32gb DDR5
Strix OC 4090
sabishiihito
Same thing here. There is an older thread here and there is also a Reddit talking on the same issue with no resolution.
